mittal_v2002
Can you please confirm if burning around 4.3GB (full DVD single layer) MKVs are read properly with rewind and forward? I would appreciate an update.
It does work. I have tried this multiple times.
Also, if someone could update on whether Sony could play MP3s across multiple folders as Samsung was restricted to play only a SINGLE FOLDER and even generating playlists beyond a folder would not work.
I am not sure how Samsung plays the MP3 files. however Sony plays only 1 folder at a time. I have not been able to find a way to create a playlist thought.. did not do much research on that in fact..
One way around to play files from multiple folders
lets say you have 3 folders F1, F2, F3 under the same directory. Now by default you can play files in only one of these as a playlist.
If you want to play files from all the folders F1, F2, F3 in sequence (all the MP3 files from the folder), keep one dummy MP3 file parallel to F1/F2/F3 in the directory structure and play this as your first file.
Once BDP finishes playing dummy file, it will jump to files under F1, play all of these.. will then jump to files under F2 and play all these and so on...
