Sound bar VFM 25k budget
Jams4znik03
Pune
I looking for a budget sound bar upto about 25k, not too rigid but around that figure with 10-15 % leeway. The living room size is about 15x 20 ft at max. for connecting it to a smart TV besides playing independent music too but the primary usage will be for movies 80% and 20% music which would be mainly pop, Bollywood, and more on the softer side. This is being bought for a cousin if mine. Basic expectation would a good balanced mix of sound, reliability and decent mix of wired and wireless interfaces for flexibility.
Since this will be in mumbai, suggestion for some good and reliable retailer outlets would be great to do a few demo tests. Appreciate If anyone has a playlist suggestion to test it, primarily which has assorted mix to test its performance behaviours in various frequency ranges. Thanks in advance.
