Sound bar Yamaha YAS 207 vs 5.1 system Sony HT S500RF
manivas
Hyderabad, India
For your budget I will recommend Yamaha YHT-1840, you can upgrade the speakers and SUB in future if required.
Second choice will be Yamaha YAS 207.
Stay away from Sony HT
Currently my tv is connected to a decade old creative 2.1 speaker setup. I am planning upgrade it. Following options were shortlisted
1. Yamaha YAS 207 sound bar https://in.yamaha.com/en/products/audio_visual/sound_bar/yas-207/index.html
2. Sony HT-S500RF 5.1 system. https://www.sony.co.in/electronics/sound-bars/ht-s500rf
Both support only basic dolby digital and dts codecs.
Full fledged avr + speakers setup is out of budget
Friends please suggest me.
If you were ready to spend on the Sony Soundbar which cost almost 31k...you will be better off buying the Yamaha which costs a bit more....possibly other dealers may give discount
Else check OLX...lots of pre owned stuff available...audition and decide...
Give JBL sound bar and Logitech Z906 a try as well
My primary desire is for deep bass, and I recently went down the rabbit hole researching setups. My budget is around 60k, and initially, I thought I needed a whole AVR setup. The plan was to start with just the AVR (eating my whole budget) and 2 speakers to get the setup started and then wait for a couple of years to save up and get a powerful subwoofer. But then I saw the comments about the JBL Bar 5.1 and Logitech z906...
The JBL Bar 5.1 (510W) is going for 60k on Amazon, I want to make the right choice. So, here's my dilemma:
How much would an AVR setup cost to match the bass of the JBL Bar 5.1/Logitech z906?
How's the overall sound quality of JBL bar 5.1/z906 compared to an AVR setup? Is it a night and day difference?
Are there advantages to the AVR route beyond upgradability and longevity?
Some folks say the Logitech Z906 competes with the JBL for bass. Should I consider it?
Both JBL and Logitech only offer 1 year warranty. How long do these systems typically last? Compared to an AVR setup?
Budget Breakdown:
AVR: Initial 3.1 setup would cost around 50k for AVR + 60k subwoofer + 60k speakers, requiring me to save up for each piece.
JBL Soundbar: One-time purchase (50-60k)
Logitech z906: One-time purchase (30k)
Is the overall sound quality of soundbars/HTIBs THAT bad compared to a custom HT setup?
Basically, if the JBL bar 5.1 or Logitech z906 can deliver as powerful bass but with a slightly worse sound quality, that might be okay. But can they compete with a custom HT setup for that deep, room-shaking experience - the kind of bass that is not just a weak rumble in the seat but is powerful enough to be physically felt rumbling through your chest and travelling down your body?
