Guys, I have purchased Bravia 47inch w850 some six months back.
I tried to setup a true surround system HERE and dropped the plan due to some personal inability.
Now i am shifting to a rental house for 2 to 3 years.(meanwhile i am trying to build a bigger house and will shift afterwards)
As far now i am using the Tv's sound paired with cheap intex 2.1 speaker system.
I am going to place the TV in the bedroom which is around 200sqft [Square in shape]
I am thinking of getting rid of the intex 2.1 and powering a new system.
Budget is upto 50K
Actually we don't have a proper audio system till now (except my signature acoustics earphones) in our house.
Here is my plan :
Buy a Good package under 50K or so and keep it in master bedrooom for 2 years.
After we move into a bigger house shift this package to some other room and build a bigger one for 1L.
For now I am confused to which i should go.
This will be used for : 70% movies and 30% music ( i would like to have good clean dialogues- i am suffering now)(have lots of BD)
This will be connected to :
1)My PC ( will be the source for all media )
2)Plex server (laptop)
Would also love to connect my phone if possible
I don't think buying separate AV receivers and speakers will hold good for 50K package will hold good.
Thinking of going between HTiBs and soundbars.
I heard that soundbars won't perform against a HtiB (?)
Currently i went through these :
Yamaha 299
Sonodyne exbar
Sonodyne pqube
Please suggest me which side i should go for and any other packages are welcome
Thank you.
Budget is upto 50K
Here is my plan :
Yamaha 299
Sonodyne exbar
Sonodyne pqube
Thank you.
