Soundbar suggestion needed for LG G3
hiugupta
Bareilly
Hello members,
I am new to hifivision community. I recently bought a LG G3 55" oled. The installation was made on April 3rd 2024. I find that its low frequency response is not very good. Therefore, I need suggestions for Dolby Atmos supported soundbar. My budget is 45K inr, go upto 50K. My room where the tv is installed is not big, it's just 150 sqft. Therefore, I do not need a very powerful system. I mostly watch OTT and play games on my PS5. I do not like having subtitles while watching the OTT contents. Thus, music clarity is must.
I have sort listed Polk Magnifi mini for the purpose, but I have never experienced its sound personally. As for samsung soundbars in my budget, they can't pass a 120 fps 4K signal through them so they are not worty for my purpose. So I request you all to help me buying an appropriate soundbar for my LG G3. Thanks in advance!
Hello members,
Welcome to HFV.
If the post / response to you helps in any way, use the 'Like' button which is located at the right hand bottom of the post. This helps to build up positive reputation for the FM (Fellow Member).
Hope you have a great journey here!
All the best!
Samsung q9xx series is the best in terms of natural sound and soundstage with movies, that you can get. Second best would be the sennheiser‘s ambeo max.
You should check out Q800C if you don't have the possibility of adding the surrounds, else Q930C. They are identical soundbars with just ghe rears added in.
I did compare many soundbars side by side on Rtings, and Q800 is the one to beat.
Intrigued why do you need 4k 120 fps pass through in your soundbar given your TV already has HDMI 2.1?
Source > TV via HDMI 2.1> Soundbar (via e-ARC)
And you won't be getting compressed audio
