Yes, they work.
What are you trying to achieve? May be there are other solutions.
Well since few days i was spending time on this useful forum, to counter the "not so good quality of sound" in my TV. And honestly i really learned a lot. Awesome community.
i was looking at the people's budget from 35K to 60K for Different AVRs + another 50K for speakers, approximately.
And though i was greedy enough to have dolby , dts, surround sound etc etc. but wondering are they so superior in terms of SQ quality.
I have a normal 5.1 channel amplifier from a local brand along with it satellite speakers are of 4 ohm and woofer is 8 ohm. And it really rocks the room when correctly configured. (it is connected via my PC currently) and four years earlier it costed me mere 3800/- only. (if i compare it with sonodyne i can only get one satellite in this cost ;-) which i think is the lowest prices quality speakers)
On further reading i discovered that most of these hi-fi systems are capable of driving 6 to 16 ohm speakers. And those which can drive 4 ohm speakers are really really fine high end AVRs. (further out of my budget)
As i spent already 71k on a TV. so wondered if i should really invest another 70-80k on AVR/Speakers.
so i am thinking to have another 5-7 k range of 5.1 simple amplifier fed by this kind of device which can decode different dolby standard and fed seperately to these 5.1 channel.
And experiment what kind of affect they give me.
if i do cost comparision ...
my cheap option going to cost me ==> 12 K [6K + 6k (5.1 amp + decoder)]
other standard option will cost me ==> 60 K [25K (Denon 1612) + 35 K (5 sonodyne genie + wooofer)]
If i see hdmi splitter (which is also primary reason for Denon thing ) is around further 5k more.
and if i am not satisfied with above experiment, then denon thing is all the time opened.
Let me know your thoughts and comments.
