Speaker stands_ my DIY Approach !!!!
Anil
You say you will allen screw the pipe to the machined brackets
how ?
please post pics
if you are gonna do it sideways?
you would be better off using CSK heads in that case
i hope you take my advice as constructive
and not consider it as pulling you down .
im just trying help you from my limited experience
P.S milling is expensive wherever you are
if youre stuck in reagurds of finish feel free to ping me
btw : is that you doing the lathe work?
Thanks buddy!!!!
Right now the problem with metal is finishing. Milling & cutting 6mm metal plate is very expensive, but the problem here is good professional finish which i am looking for. Suggest me a good workshop who does good job in Bengaluru. I shall look in to adapting metal base in my next project.
For good stability i am attaching a 1.5 kg MS counterweight at the bottom plate, so CG will be shifted to base.
Anil
Anil I have some idea's for using the raw metal and still maintain the finish !! Will explain when I meet you on Monday ;) !! if you use that idea,you don't have to get it milled and all,just get the metal sheet (preferably a 8 or 10MM as 6 I think is too thin ) cut in a neat manner ! you can get it done in N.R.Road where you probably will buy them ;) !!
Regards.
how ?
please post pics
Hi magma thanks for constructive advice.
Allen screws will be fittred from sideways, there is enough room for the screws. Brackets are 15 mm thick, i think pictures should give you some ideas, i shall post it soon.
No magma, it's not me, i have no experience in handling the machine. I get the work done.
Anil
MY DIY Speakers :)
Thanks Sreekanth.
regards,
Anil
MY DIY Telescope :yahoo:
Regards.
There was some progress on Saturday.......
Beveled rubber wood. Sanding is yet to be done.​
Some progress last week........still lot to be done, hope to complete the stands by Saturday.
Machined spikes​
