Flash
Yes reignofchaos I am looking at buying the pass labs NP 20 preamp and pass labs XA 100.5 power amps .. Source is undecided at present
Thanks for the suggestions . I have frozen in on the speakers. They are being shipped from the US. Will reveal as soon as I get my hands on them
Not sure which study you are referring to. But NRC Canada, Floyd Toole and Olive, and Boston Acoustic Society and D R Moran have done numerous studies with most expensive systems where amp did not make a difference. you can also read Alan's Forum. He is president and owner of Harbeth.If you have the right setup like Super highend speakers and good DAC it will be very clear that you will say that all sound different.
There are even situations when we have changed 20 cables one by one the difference was very evident.
Everything will make a difference. The paper by Harman is not wrong but its for entry level audiophiles. Once they get experience their listening maturity will increase. Im not debating here or else everybody will not buy highend setups. Many buy highend amps even by comparing with their previous amplifiers.
preamp certainly makes difference simple logic: if pre Amp can make difference then Amp also makes difference since the only difference between the pre and power is just the value of power output nothing else.
But if you believe in the hype, I am ok. Even if you don't believe in all the measurements and research about power amps, Please do believe that cables don't make a difference as long as they are properly made with sufficient guage wire. The engineering data and literature is truly enormous in this area.
I believe the decision has already been made...
It is surprising that questions that were researched and settled in 80s and 90s are resurfacing again. Naim was the company that I believe started this tend in power amps.
Nothing in audio is settled
@Flash: I am tone deaf and cannot make out difference between amps. Can I have one amp please :yahoo: (I'll take whichever is cheaper)
Hahahahaha Joshua ... I forgot to put a disclaimer: Tone deaf participants are not allowed for the blind test .
I would not mind just taking part to listen to the new speakers
Ok, enough OT
We want to read a small review of the new speakers whenever they get delivered
