mohitsomani
Hi all,
I'm planning to buy FX Audio M160E Stereo Amp from HiFiMart but I'm not sure which speakers will be better with it. my budget for speakers is 15-17k max. Amp has 65w per channel at 8 ohm power output and is available at 8 thousand rupees.
Also, if there something better available in this range, please suggest that too. my minimum requirement is the amp should have Bluetooth.
Thank You,
Mohit
Thank You,
Mohit
