Speakers for Trance Music under 20K
I received my Asus Xonar STX yesterday. The difference is apparent but should play true to its potential after 50-100 hours of burn-in.
Go for Audioengine A5. They are really good sounding. I haven't heard Swans though.
On Techenclave , they are selling for Rs 7,200 .May i ask where did you buy STX from ? I've ordered Swans M200MKII since they are slightly better than Audioengine A5 after concluding from on several different forums.
Can anyone please suggest weather i should go for STX or USB DAC ? I wish to connect my speakers/headphones via laptop too . Is the sound quality between STX or any cheap USB DAC (under 7K) apparent ? Thanks.
See, if you want to connect your spks via laptop then there is no question of STX. You have to go for USB DAC.
I haven't heard any USB DAC. Other FM may help you on this.
Thanks for the info . There is also a USB option for STX. But it's quite expensive at around 25K :eek:
Dunno why but USB DAC looks more convenient , handy and portable . I don't think it will be able to perform near. STX . I might want to start a separate thread for DAC recommendations.
I bought it from this seller on Ebay.
But on Ebay it is out of stock now. In Hifimart there may be available, just check with them.
It's really strange STX is out of stock everywhere . Even at Hifimart. . These are the websites i checked -
1.Techshop.in
2.Officeduniya
3.Hifimart.
4.PristineNote.
5.Primeabgb.
Any other recommendations ?
