mandeep
Dear all,
Plz suggest best matching bookshelf speakers to pair with Yamaha RX-A3050.
Yamaha have a high power of --- 150 W per channel (8 ohms, 20Hz-20kHz, 0.06 % THD, 2 ch driven) and high dynamic range for speakers ohm ratings 8/6/4/2 as 175 / 220 / 295 / 410 W.
Now the problem is , that due to space constraints I can only use bookshelf speakers and most bookshelf speakers do not fall within that power and dynamic range of the amplifier.
Eagerly waiting for your advice.
Thanks in advance
Cheers:cheers:
Thanks in advance
Cheers:cheers:
