Hi Guys ,
for the past couple of months I have been working on a amp design and its finally complete. Man it was some hard work sweat and tears , but the final outcome has been very pleasant. The listening impressions have been phenomenal too , the lows are powerfull beyond comparison , while the mids are clear and very upfront , while the treble is ever-present and soothing on the ears.
thanks
Aniket Das
thanks
Aniket Das
SS2400 - STEREO POWER AMPLIFIER SPECIFICATIONS | |
Topology | Class-AB |
Channels | 2 |
Power Output | |
4Ω SCD (Single Channel Driven) | 440W |
8Ω SCD | 240W |
4Ω BCD (Both Channel Driven) | 400W |
8Ω BCD | 220W |
Frequency Response | 10Hz - 25kHz |
Signal to Noise Ratio | > 95dBr |
THD+N. 4Ω, 8Ω. 1kHz | < 0.001% (-3dB) |
Minimum Recommended Load Impedance (per channel) | 4 Ohms (which equals one 4 Ohm load or two paralleled 8 Ohm loads). |
Damping Factor | > 400. |
Input Sensitivity | 1V. |
Gain | 40 dB. |
Input Impedance | 22 kOhms. |
Input Connections | Unbalanced (RCA); one each per channel |
Speaker Output Connections | Audiophile grade 5-way binding posts. |
Power Requirements | 230 VAC @ 50 / 60 Hz |
Status LEDs | Green - Lights up at -10db Output Green - Lights up at -3db Output Yellow - Lights up at 0db Output Red - Lights up at Clipping Red - Lights up to indicate a fault condition. |
AC Power switch | Rocker switch (switches AC main power). |
