Need Help. I am looking for 2.1 setup for my TV, to start of with.
Need your feedback and suggestions for what I am trying to do.
I have a topping MX3 amplifier DAC for my PC. I plan to use this first, get a decent set of speakers. I am planning to get the Jamo S803 (in white, I think) first and then add a SW later after a few months. Upgrade to AVR maybe after 1 or 2 years & then add surrounds gradually.
Do you think these speakers are not the best value for money. Since these will be in the living room prefer looks as well sound. I do not want to spend more than 30K for L & R speakers+cable+stands.
Do you good folks have any suggestion for Good speakers (Looks good and sounds good as well)since they would be in the living room. Also, since this would be mainly used for TV prefer the sound signature which is a slight smile (slightly enhanced treble and bass) & a wide sound stage.
Lastly the woofers what are some good recommendations for some decent Subs which has crossover settings/controls, Subs which are not too boomy.
Or do you all think all this is not worth it & I just get a decent soundbar with wireless subwoofer (samsung Q800t or JBL Bar 5.1 Surround or Bose 500)
