Streaming device advice
Should I buy from Amazon.com is that correct? I read some reviews that it bit headache to make is working. Playstore won't work easily due to county ? Is that correct. Chromecase - does it support installing KODI as well ?
Not correct, its easy to setup and no issue with playstore, you can use your Indian playstore account and almost all local apps are available, Been using Shield (2017 than 2019) for past 4 years +.
I would recommend Firestick 4k since last one year using excellent picture quality as well as sound quality.
Cool 👍
Ahh that was based on a feedback from Amazon.com, hence asked. Thanks for your inputs
