Sub-160K 55" LED TV
Polaris
India
Can I get some recommendations for a sub-160K LED TV? 3D is not particularly important. Nor are the speakers (as I'll be piping it via the HT). My requirement is a fantastic screen. Please also suggest a good (and reliable) dealer in Chennai.
Thanks!
Thank you. I'm seriously considering the w800a which looks great (even if it seems a little too vibrant, if that's possible). Is there any difference between it and the W802a which is being reviewed overseas?
Thanks again.
Thanks again.
No. It's the same television. Only difference is in the color system/television standard ( NTSC/PAL)
Thank you. Any idea if the Indian editions support USB recording? Apparently, the European versions do.
Anything else I should keep an eye out for?
With a 155k MRP, perhaps I can squeeze a dealer down below 140k?
