So whats the point in buying a 1 lakh plus bookshelf speaker when you have to shred another fortune on a sub woofer to the get it sound right????
Doesn't make sense.
There are plenty of 2000/- speakers that will go down to as low as 30hz vs the say 50 that  the LS50 will do.. Doesn't make the former better.
There is a lot of misconception about stereo setups and subs and bookshelves.
Lets say you have 3 systems
A- Floorstanders capable of going down to as low as 30hz coupled straight with a stereo amp
B- Similar make Bookshelves that go to say 50 hz coupled with a stereo amp along with a decent sub that goes down to say 22
C- Same bookshelves as B but no sub
In a perfect world, B>A>C
The problem is that it is extremely (and I really mean it) difficult to get the crossovers, placements and levels to a point where B actually gets better than A
More often than not, (in the real world), A >C>B
And that is because there will be frequency overlaps , standing wave interferences and level mismatch between the sub and the low range driver on the bookshelf
Is it possible to get the balance right - yes, but you need to do a lot of work to get it right
Most people try to do it the old fashioned way i.e. play a few tracks and experiment with the settings - almost a certain recipe for failure other than for very few and hence the prevalent belief that subs make stereo setups worse
