Vikramdeals
Hi All,
This forum has been extremely helpful to me in the past and it gives me courage to put forward another help request.
Last year Flash and other forum members have been great help to me to decide on AVR that is Denon AVR 1912 during my trip to UK. This year around I am in the US and this bug of buying sound equipment struck again.
Due to budgetary issues I couldnt invest on speakers and might do it post trip in Jamo S426 to begin with. However I wanted to know since I am in the US, is it worth enough to buy a Subwoofer from here?
Has anybody tried taking the subwoofer as check in luggage from US back to India?
So precisely my queries are:
- Currently I am using Denon AVR 1912 with local speakers (BS) I had from my previous set up, it is doing decent job however when playing movies dialogues are not loud enough and if I raise the volume any special effect sound so loud that I have to bring volume down. I got a suggestion reading this forum that it is imperative to add centre speakers to solve this issue is it correct?
- I am planning to buy Jamo S426 once I am back in India as my budge sits around 20k. Do you think it is worth going for a combination of Denon AVR 1912 and Jamo S426 or go for separate Floorstanders or just buy centre to begin with? What combination should that be in initial set up?
- Lastly being in US I am aware that I would not be interested in carrying 5.0 set up as my luggage instead I wanted to check if I should make an attempt to buy subwoofer here? (This would be in addition to my budget of 20k to spend in India) If subwoofer is good enough to be carried to India, are there any suggestions for entry to mid level subwoofers to go with Denon AVR 1912, so that I can look deals around and order it in next couple of days? Any other drawback carrying the subwoofer from here?
Your suggestion/help would be much appreciated as always.
Cheers All
Cheers All
