Narayana
Hi iam using denon avrx1550h reciver with Taga harmony 606v3 speakers using front 2 tower speakers now I want to purchase subwoofer my room size 4/3 metres
Thank you@Narayana if 25k the you can buy 2 of these yamaha subs
https://htstore.in/index.php?route=product/product&path=109_61&product_id=996
you can buy 2 of these pioneer
http://sayhifi.com/index.php?route=product/product&path=261&product_id=409
jamo
http://sayhifi.com/index.php?route=product/product&path=261&product_id=359
Taga harmony
http://sayhifi.com/index.php?route=product/product&path=261&product_id=330
Seems like sayhifi is inactive. Even their phone number is not working. Did they stop their services?@Narayana if 25k the you can buy 2 of these yamaha subs
jamo
Taga harmony
Go for Yamaha sw300. Will cost you 27k. Rated at 250 rms nd goes low as 20hz.RS
20 to 25000
Thank youGo for Yamaha sw300. Will cost you 27k. Rated at 250 rms nd goes low as 20hz.
which sub did you buy?Thank you
where to get Yamaha sw300 for 27k?Go for Yamaha sw300. Will cost you 27k. Rated at 250 rms nd goes low as 20hz.
@zeeya recently got it in blore for 27k. You can check with any dealers that sell Yamaha products. The MRP is 32 k nd at discount it is sold for 27k.where to get Yamaha sw300 for 27k?
Also in Youtube i am not finding much reviews about the Taga SW10 v.2 .Yamaha SW300 they have rated it Best 5 budget Subwoofer 2018.
