Hi all ,
i am planning on making a passive subwoofer for my home setup , i have shortlisted the following drivers
1. Peerless 12inch aviable from Varsha electronics with the following specs
Peerless Fabrikkerne (I) Ltd - 12" Sub-Woofer
Features: Coated paper cone with durable foam surround.
Stamped Powder coated Chassis.
Technical Specification:
Parameter Value Unit
RMSE - Free 0.43 Ohms
Fs 25.01 Hz
Re 3.68 Ohms
Res 9.69 Ohms
Qms 1.17
Qes 0.45
Qts 0.32
L1 0.53 mH
L2 1.11 mH
R2 6.09 Ohms
RMSE - Load 1.01 Ohms
Vas (SD) 256.35 Liters
Mms (SD) 59.71 Grams
Cms (SD) 678 uM/Newton
BL (SD) 8.80 Tesla-M
SPL ref (SD) 94.7 dB [Re]
Rub -Index 0.14
Xmax mm
Area (SD): 518.75 Sq.Cm
Impedance 4 Ohms
Frequency response 26 - 220 Hz
Method: Mass loaded - Mmd (100 Grams)
DCR Mode: Fixed (3.68 Ohms)
2.IWAI SUB-WOOFER 12 4? 200W with Shorting Ring
Electrical
Nominal Impedance 4 Ohms
Resonance Frequency 25 Hz
Power Handling {IEC-268-5C} 200 Watt
Long Term Power {IEC-268-5L} 600 Watt
Short Term Power {IEC-268-5S} 1000 Watt
Sensitivity (2.83V/1m) 91 dB
Resistance (DC) 3.5 ?
Qms 6.91
Qes 0.43
Qts 0.41
BL 14.23 T-M
VAS 86.57 Litres
Mechanical
Voice Coil Dia 50 mm
Winding Width 32.60 mm
Former TIL
Layers 4
Wire Type Copper
Magnet 134 mm
Cone Material Paper
Surround Material Rubber
Chassis Powder Coated
Dust Cap Paper
I have simulated both the driver in WINISD and found that the IWAI one has a -3db roll off at 44hz where as the peerless one has a roll of at 54hz ....
Both being a sealed box of 44L and 66L respectively , Can anybody share their experience with the peerless subwoofer i know many have subwoofer using the peerless one ...
Fs 25.01 Hz
Re 3.68 Ohms
Res 9.69 Ohms
Qms 1.17
Qes 0.45
Qts 0.32
L1 0.53 mH
L2 1.11 mH
R2 6.09 Ohms
Rub -Index 0.14
Xmax mm
Impedance 4 Ohms
Electrical
Qms 6.91
Qes 0.43
Qts 0.41
BL 14.23 T-M
VAS 86.57 Litres
Mechanical
Former TIL
Layers 4
Wire Type Copper
Magnet 134 mm
Cone Material Paper
Dust Cap Paper
