Thanks everyone, this project would not have seen the light of day, if it weren't for the tons of support, encouragement, feedback of the OB -Audio-Mania WhatsApp group, several of whom are members here. And a very special call out to
@yogibear for getting us ordained into pleasures of the OB sound, the countless videos and sample clips that he patiently posted, even catering to demands for specific tracks - pretty much on a full time basis. Furthermore, for
@yogibear 's infinite patience and guidance both of which were critical to my learning process.
Another FM who was very key to the success of this project was Shiva Prashanth Hiremath (not sure of his handle here), for the Fane Woofer, else this project would have been considerably delayed. Shiva also helped in the listening sessions helping to fine tune.
Just got back from work, it is a bit late in the day for taking pics (I don't use flash as a matter of principle and do not own one), will shoot some pics tomorrow and post it.
Some initial pics from the construction phase
Panels are double sheets of 20mm MDF, the greening tinge is due to the MDF quality - it is external grade, it is more dense and uniform
Speakers on the way home in the car.
Rear View - you can see the 'hat' over the woofer, and the Apex Jr. plate amp. Yes, the speaker cables are Finolex 2.5 sqmm
first placement of the speakers as they were unloaded from the car. They have now been switched. You can also see my towers, and the sub. To the far left is my DIY rack that holds all the equipment. This whole lot takes up a full wall in the living room - very questionable WAF at the moment
Listening Impressions
Here are the listening impressions that I posted on the WhatsApp group in chronological order, it will also show how the sound has changed due to breaking in of the drivers.
- First Reactions
To me it just sounds natural and right, there is something RIGHT about the sound, an elusive quality that you keep looking for when you audition equipment, but you find something missing all the time. I am just listening to the third track and it sounds so good...
No resonance, bass is tight and very smooth, there is no perceptible transition between the F6 and the Fane. The Fane is crossed at 140hz. And the F6 is direct to the amp
I'll play some bass heavy tracks later today and share my impressions. Yesterday rock was sublime. Jazz even more so, esp. female vocals like Norah Jones, was silky smooth.
- about a week later
- The OB loves hard rock and metal - both the F6 and the Fane seem to revel in it. Clear separation of instruments, great vocals and rounded out HFs.
- The Fane needs to break in, hard rock and metal have a lot of hard hitting bass - the speaker has no choice but respond. However, some more hours of usage will surely free up the suspension a lot more and I do expect bass to open up
- so far I've been using the XO settings on the Apex Plate Amp, there is a bypass option and I'm planning to switch to the pre-amp's filters (much better quality and wider range) to set the XO for the woofers. Also gives me some level of consistency between the channels.
- Shiva Prashanth Hiremath felt that the plate amps don't have the strength to really drive the bass. Perhaps an upgrade to more powerful amps are needed. We did discuss the possibility of using a Crown or something like that rated about 2000 Watts to power the woofers
- which brings me to my next point - these babies are really power hungry. The F6 holds out - even at somewhat elevated volumes. But the Fane needs more power, I guess it is not so much about the efficiency of the driver itself - but the efficiency of the system overall. Producing copious amounts of bass requires copious amounts of amp power.
- about a month later, @Kannan asked me a very relevant question: How does the OB compare to my towers? and my answer follows
The OB - sounds open, airy, detailed, lush, articulate and expressive, great for music, pretty much all genres, but really shines on all genres of rock, metal, pop, jazz and Western classical. On movies and TV (e.g. GOT), the dialogues are clear, and place beautifully on the sound stage, the imaging is spot on. Turn up the volume and the speakers can heard all the way near our gate, about 100 meters away. What surprises me is the power handling capacity of the F6 - I do believe it can handle much more than the 10W that it is rated for, I've turned it up to near ear bleeding volume with hard rock and it didn't miss a beat - am not sure how long the VC can handle this abuse, but I did not see any signs of stress or distortion.
My Towers (The Sentinels - named by wifey) - sound laid back, mellow, smooth and un-fatiguing for all types of music, it is more forgiving of bad recordings and MP3s. Vocals are bit more rearward placed on the sound stage, with a more vertically diffused image. Bass is more punchy though not quite as articulate as the Fane's in the OB. The diff being, the Fane's get dedicated amps, as opposed to The Sentinels. The towers shine on movies, Batman, Transformers etc., with good background scores sound almost as good as the movie theater or even better at home. And when turned up, The Sentinels can pound hard.
above feedback is based on my 55 year old years, that can't hear anything beyond 17KHz...
Fantastic imaging, natural sounding for all manner of vocals
Instruments are nicely delineated and articulate
Bass is tight, articulate, deep and powerful - another woofer and a stronger amp would be welcome - I love musical bass
Rock, pop, hard rock, classical, baroque and metal - in short all genres - some thru very clean and effortless.
The F6 is very detailed and will bring out everything from the recordings - good, bad or ugly - on truly good recordings, I can hear detail that I haven't heard so clearly before....makes me want to listen to my entire music collection again.
and surprise - sounds great for movies as well, dialog, music and action sequences - the F6 does not even blink and the Fane Woofer just keeps on going too
OB has been a revelation of sorts.
Equipment
| Source | Oppo 103 - portable HDD plugged into the BD Player |
| DAC | Emotiva XDA2 |
| Pre | Emotiva XSP1 |
| Power | Emotiva XPA 200 |
| Subwoofer Amp | Apex Jr 250 W |
| Cables | All DIY |
| Room treatment | none |
