Here is the Subwoofer plate amp pic from Rythmik Audio. I've highlighted the terminals
The Line out is filtered at 80hz . However it has a parametric EQ so I will be able to fine tune integration.
So without a sub out from the preamp. I would have to run cables from preouts of preamp to Line in on Sub and in turn line out to Poweramps which will filter 80hz and below from going to to the speakers.
However the best place for the sub is approx 20 feet away however the RCA's would run 30 feet each cable.
So not too sure if there is another way out. Or rather will I be able to use well shielded RCA's and run it through a conduit away from power cables to avoid ground loops.
Would there be any signal loss ?
Hey Flash, I'm curious how did you solve the issue. Have you used a splitter? Unfortunately your sub doesn't have balanced in, else 20' balanced cable would've been possible.
