subwoofer connections
Nickhill007
Pune
Hello
I own a paradigm 3100 subwoofer and a denon avr x2000 please help meout as to how do I connect these:sad:
Hi I had the same dilema and reserached a bit on the web and connected.
jsut connect the subwoofer Preout to the white LFE terminal on your woofer(Even you can connect to the red one also).
Put the Freq at 12' O clock position as a starting
You can connect SW preout of X2000 with coaxial cable to Left input of Paradigm SW.
There must be LFE written.I cant read in picture though but see something written near Lt/white input of Paradigm.
I would need a Co axial subwoofer cable can any one suggest weather its important to buy a branded cable for the same ?
you are right,I cant read in picture though but see something written near Lt/white input of Paradigm. thanks
w24mVL
