Subwoofer for focal 836v
hemantvj
Hello Dear Frnds
I have a small set up of FS focal 836v with the center 800cc. I would wish to compliment the setup by adding a Subwoofer(other than focal SW800) to be bought locally(no import) having after sales provisions. Can any one suggest the best value proposition suiting the focals. Appreciate help. Cheers Hemant
If you have a choice between Polk and paradigm subs, then I would suggest to go for paradigm subs because of their solid track history and quality output. Depending on if you want to use for music or movies get a sub wherein you have an option to adjust the gain. Also for the price that you maybe looking at you probably may have other options as the ultracube is not too cheap.
Thanx Marsilians. Need to study more on the "gain adjustment" you mentioned. Need to check if I get any good deal on paradigm subs locally
