BA ASW650 is a very good choice. If you can extend your budget by 5k then the velodyne impact will be an optimal choice.I have Pioneer VSX329K with Boston Acoustics A25 as fronts.
I want to add a subwoofer to it. What should i buy and from where
Using the AVR with HTPC
Room size-12 * 15
Budget 20K-25K
Hello... I am also running the same parallel thread for subwoofer to hookup to my pioneer elite receiver. (http://www.hifivision.com/speakers/54229-confused-about-subwoofers-one-more.html#post617923) Please check out if possible.
I did audition polk psw110 (which was good for music) and focal cub 3 (which was very good for movies) ...
I heard good things about Velodyne and BIC - but still waiting for reviews of BIC in this forum. Hope this helps.
I don't think PSW110 is @ 24k... It was something around 18k.. PSW 125 is 24k at ProFx - Profx - Advanced Audio SolutionsYeah I did read your thread.
Polk PSW 110 (not auditioned) 24K
Do let me know your impressions on Sonodyne rorr post your audition.
Hi AK1980
Good value for money....Boston Acoustic ASW 650 .....excellent for music / movies / gaming.
Been using the same for 6 months...perfect!
Call them before a demo I purchased my Polks from them. The PSW 110 is available for a demo. In case you are buying it ask them discounts too they generally give 10% they may give a little more if you insist.Yeah Ur right just checked on Profx website and confirmed at their showroom it is 18.5 K
will go to Profx Showroom at Phoenix this sunday to check it
