Subwoofer Help
shitikv
chennai
Hey
i have a YAMAHA RX-V520. yeah its like super old :P. (waiting for the new hdmi 2.1 receivers to update).
i think my room size is about 10x13
i only have front tower speakers as of now. some brand called polyway (MADE IN USA Apparently)
the above setup of mine is i think atleast 12 years old i guess.
i was looking at a few sub-woofers. budget about 20-30k
Polk Audio - PSW10
Polk Audio - HTS10
Yamaha NS-SW300
out of budget
Q acoustic qb12
what do you experts suggest among these? or apart from these
below are the amp and speaker specs
Amp : Yamaha RX-V520
Minimum RMS Output Power per Channel
MAIN, 1kHz, 0.07% THD, 8 ohms - 100W + 100W
CENTER, 1kHz, 0.07% THD, 8 ohms - 100W
REAR, 1kHz, 0.07% THD, 8 ohms - 100W + 100W
Dynamic Power per Channel
MAIN, 8/6/4/2 ohms.....105/125/145/165W
Front Speakers:
Brand: Polyway (never heard of it)
Specs:
Frequency Response: 30hz - 22000hz
Sensitivity: 94dB
Impedance: 8 ohm
Recommended 20 - 150 w
Crossover - 24dB
Hey
i have a YAMAHA RX-V520. yeah its like super old :p. (waiting for the new hdmi 2.1 receivers to update).
Polk Audio - PSW10
Polk Audio - HTS10
Yamaha NS-SW300
out of budget
Q acoustic qb12
Front Speakers:
Specs:
Sensitivity: 94dB
Impedance: 8 ohm
Crossover - 24dB
Hts 10 or sw300 hear them out if possible and then decide
do you suggest anything else from the list?
was just checking on my room size its 12x14
and the space i have for the sub is approx 14 inch in width
sharing the pics.
the only place i have for the woofer is on the left side. close to the speaker and the door.
Based on your very strict budget, I would suggest Yamaha NS-SW300.
In case if you want to increase your budget a bit more then would suggest BiC America PL200ii, again if you want to increase your budget then would suggest svs pb/sb 1000 and so on... :)
hey thanks for the reply! but thats way out of budget :p
if only svs sub was within 40k:p
i can stretch it till 35-36k at the max
how about the
klpisch r-100Sw
bic america f12
Elac Debut 2.0 S10.2
just too many choices got me confused :p
If you are not able to review the suggested subs in person..read reviews on this forum or google..there are ample review videos on Youtube,,just type the sub name and model
