Subwoofer repair in Hyderabad
chaitanya.v
Hyderabad
Hi all- Recently my subwoofer has started making a tapping sound that's only noticeable at high volume levels. Does anyone know a good contact who can repair the subwoofer driver?
Open the subwoofer once and check what is making the noise.
Is it the wires touching the spider or is it the cone/ spider pasting etc.
You can past it using fevibond
I appreciate your suggestion. Even though I'm not an expert, I'm thinking of giving it a try. Could you let me know the dos and don'ts to keep in mind while removing the drivers? I want to ensure I don't make things worse in the process.
Just do not pull too hard if something is stuck. You might break some wire. Otherwise it is an easy process of just unscrewing the subwoofer. Then take it out while it is still connected and play it and check which part is making noise. Take some picture or make a video and post here
Update:
"I've identified the problem. The screws holding the driver in place were loose. I'm not sure how they came undone, but I've tightened them, and the tapping sound has disappeared. This means the issue wasn't with the driver itself, as I initially suspected."
Thank you all for the suggestions 🤝
