Is HTS ,REL zero still behind in quality(wrt-marantz 1509) as compared to America 200, suggest plIf possible then 4K stretch is worth it.
REL T-Zero is aimed at desktop use with mini speakers.Is REL zero accoustics will good to go with marantz 1509,pl suggest
Grt you have cleared my daught. Removed REL from my list....for 10" what sub you referREL T-Zero is aimed at desktop use with mini speakers.
It has only a 6.5 inch woofer. It is kind of a powered woofer
Will not pressurize the room for AV application.
I have tried REL T5i (8") and found it lacking in my listening space.
Good, but definitely leaves you wanting a bit more.
If your primary use is HT, REL T series is not the ideal match
Raghu
I will be able to streach little....( Pl suggest wrt marantz 1509)Grt you have cleared my daught. Removed REL from my list....for 10" what sub you refer
Bic pl200ii taga sw10 v3 bic f12I will be able to streach little....( Pl suggest wrt marantz 1509)
Thanks brother for the quick input....room size is 11"12The most important information missing is how big is the "small" room
AVR doesn't have anything to do with the sub, other than pass along a signal.
The volume of your room and the geometry, will help other FMs knowledgeable in this area guide you.
Raghu
It will lack power..Is HTS ,REL zero still behind in quality(wrt-marantz 1509) as compared to America 200, suggest pl
And just share what's your requirement and budget..
Thank you..I believe he is looking for sub for movies within a budget of 40k as per his posts.
Budget is 40 approx room size is 11*12... Pl suggest a good sub which go with 1509It will lack power..
Like others have already suggested BIC PL200II is a very good 12 inch sub that you can get in ~40k range. FM @Michelangalo got the sub from an online retailer for 44k.
Grt help ,appreciate your suggestions....Like others have already suggested BIC PL200II is a very good 12 inch sub that you can get in ~40k range. FM @Michelangalo got the sub from an online retailer for 44k.
Polk HTS series is also a budget buy, along with Taga Harmony platinum SW-10. Above mentioned subs work just fine in your room if you invest sometime positioning the sub properly.
If you are interested in taking the pre-owned route, there are few subs already listed in the sale section of the furum.
REL T series subwoofers are typically recommended for stereo application. They have HT series that you may take a look, if interested in REL.
Hi all.
Apologies for hijacking your thread @Sarfraz
I am also looking for a decent <40k SW for my YHT1840. This is the sub that I will be using in my future build. Going through various SW threads, the general recommendations here is BiC F12(36k on jamaticks), Yamaha NS300(~29k), and Taga platinum SW10 v2(31k). I hope I am not missing other good options.
BiC F12 is the highly recommended one. There is a query though, if someone can clear it out. I live in a tier2 city. The only Hifi store here deals exclusively in Yamaha, and can arrange Polk, Klipsch, Jamo. What worries me is the warranty. This is one of the reason I am inching towards Yamaha. Locally available and hassle free service(no courier and all), at least for an year that yamaha offers.
The folks using BiC products, how it is performing and should I take the risk of buying one from jamsticks(for 37k)?
If you are considering Bic then go for Bic Pl200 II. It's more refined than F12, only minor price difference. Bic has extended 8 years parts on woofer, 5 years on amplifier and associated electronics. Bic is not recommended if you lot of power fluctuations but again that is also a concern with most avr an recieved. |
The warranty is really something exceptional, 8 years!
Also PI200ii is currently for 47k and available only on jamsticks. Hopefully will drop down to 44k. F12 is for 37k now. That’s a 10k difference, although with equal performance difference also.
It’s best to wait for a while for price drop.
Thank you for the help
Hi all.
