sujithblaze
Looking for a subwoofer to go with my denon x2600h and pioneer Andrew Jones speakers room size is 10*12 budget under 40k
Have you heard R120 and SPL-120 both? Is SPL-120 a significant improvement over R-120?My vote for Klipsch 12 inch.
I haven’t. I have heard the SPL 150 though at Cinebells, Bangalore. The SPL is a newer model, and supposedly has amp improvements over the R series. The R120 still seems to have good reviews on the net. There is a chance you might get a good deal on out going R series.Have you heard R120 and SPL-120 both? Is SPL-120 a significant improvement over R-120?
Thanks for the input even i was interested in the yamaha ns300Going purely by prices (in Bangalore), here are a few options that I had considered, recently:
BIC F12,
Klipsch R-SW100,
Klipsch R-SW120 ((slightly above 40K),
Yamaha NS-300,
XTZ 8.17 (slightly above 40K)
Taga SE 212
I bought the BIC F12 -- but, might become boomy for your small listening area.
Even i was interestedMy pick, NS-300. Excellent performance, goes very low (20 Hz claimed), high output (250 watts RMS), very good for both movies and music. Garnered rave reviews all over the world for its performance. And all this for 30k. Do give it a serious look.
I believe 12 inch would be an overkill in my small room,so looking for 10 inch subsThis is my first post in this forum, quite excited to be here. Yeah, HTS 12 is a good one. Bargain with the dealer and you can get a deal.
Guess the hts12 would be overkill, i am interested in hts10 nd the ns300 from yamahaI am using POLK HTS12 for over 6 months and very happy with it. Retails around 45K. Check it out at profx
To make matters worse its a tiled room with no carpetsFrankly i dont think a 12 inch sealed sub would be an overkill, i use one in a 13 by 11 room and dont find it to be boomy or overpowering for the room.
