Suggest a decent Indian amplifier for home
AbhiShek.
Jalandhar
I'm currently staying in Ludhiana. Good Indian amplifier brands are very hard to find here.
Please suggest some good amplifier and place where I can buy them.
Delhi is approachable.
Your question is quite an open ended question with no details.
I suggest you go through these threads listed under Amplifiers-Receivers.
Surround Amplifiers/Receivers
Take your time, maybe a week to digest all the information. (You can even google up external sources for additional information)
At the end of it you would have a fair idea of the following
- Types of amplifiers
- Inter dependency with the Speakers they are driving
- Features & Interfaces supported
- Price Range
Once you have this info the next step is have a budget in mind ( Taking into consideration the speakers you need to buy or upgrade or already have)
Note : After this depending on your enhanced knowledge you might want to change your budget / requirements.
Then come back with specific questions about a product you have in mind.
You will get a better response. :cheers:
Topping 2020 amp is great. Costs aroung 5k. You can buy one from eBay. The seller's name is indeed labs.
Around 10-13k
Abhishek, increase your budget to around 18K, and look for amplifiers from DNM. They are extremely decent amps. I have been listening to their A-302 for the past one week, and I am extremely impressed by their build quality and the quality of the music.
cheers
I have recently bought Norge Amplifier from Eastern Electronics, Mahim Mumbai. Great Guy, Great Amps...Great sound...
I am glad you are looking for an Indian make buddy. Norge anytime!!! Tried and Tested hence recommending.
Eastern Electronics
225, Hammersmith Industrial Estate,
Sitladevi Temple Road, Mahim,
Mumbai 400 016
Contact : +91-9821871023 / 91-22-2446 6627
Email : [email protected]
Kaustubh G
I would suggest you also check out amps in a higher price bracket. You just might be tempted to save up for something better :lol:
