Vinayak@
Which is better audio quality-wise, LG V30 mobile or Fiio BTR 30 Pro DAC? Or any other ?
Could you please brief on your setup?Which is better audio quality-wise, LG V30 mobile or Fiio BTR 30 Pro DAC? Or any other ?
Then why would you need another entry level dac?I use a Topping DAC - works well with my Ubuntu laptop. Shoutout to mBhanghui for helping me patiently to get it to work
Add topping E30 to the listWhich is better audio quality-wise, LG V30 mobile or Fiio BTR 30 Pro DAC? Or any other ?
What is your audio source and setup?Which is better audio quality-wise, LG V30 mobile or Fiio BTR 30 Pro DAC?
The Fiio 30 BTR DAC is made purely for audio purposes unlike the LG that can do many other things.Which is better audio quality-wise, LG V30 mobile or Fiio BTR 30 Pro DAC?
Thank for reply I have already buy Fiio BTA30 Pro ...very awesome sound quality....But when you try to use the another mode, the there was some trable to connect but when connected it's everything work fineThough I am a big LG fan and currently using V40 in my setup.
FiiO seems to use a way superior DAC chip - ESS ES9038Q2M which has been used in many critically appreciated DACs such as SMSL U6 and even in the Audiolabs 7000A integrated amp
Got a Khadas Toneboard VIM version 2-3 weeks back. Connected it to Asus Tinkerboard 2S running LMS through USB. Way better than iFi iDSD Nano I have. It can run from a PC or Mac USB too. Also can work as a SPDIF DAC and I2S DAC (yet to try).
Tone Series | Khadas
Hi-Res Audio Board Designed for Music Fanatics | Hi-Fi 2.0 | XMOS XU208 | ESS ES9038Q2M DAC | Volumio | DSD | S/PDIF IN | USB Sound Cardwww.khadas.com
you have a choice of getting a fully built one (ToneBard 2 with Balanced / Unbalanced output) or barebones that can go into a small acrylic box that you have to make 4
Is there a way to order Khadas Pro 2 to India. I am planning to use it for my Kanto Y6 conencted to Pc.Got a Khadas Toneboard VIM version 2-3 weeks back. Connected it to Asus Tinkerboard 2S running LMS through USB. Way better than iFi iDSD Nano I have. It can run from a PC or Mac USB too. Also can work as a SPDIF DAC and I2S DAC (yet to try).
make
Sorry @rajivaryan1984 I am in UAE and Amazon UAE do list it here. Got from themIs there a way to order Khadas Pro 2 to India. I am planning to use it for my Kanto Y6 conencted to Pc.
DACs and DAC chips have improved by leaps and bounds in the past 10 years compared to other products typically found in hifi chains.Got a Khadas Toneboard VIM version 2-3 weeks back. Connected it to Asus Tinkerboard 2S running LMS through USB. Way better than iFi iDSD Nano I have. It can run from a PC or Mac USB too. Also can work as a SPDIF DAC and I2S DAC (yet to try).
you have a choice of getting a fully built one (ToneBard 2 with Balanced / Unbalanced output) or barebones that can go into a small acrylic box that you have to make 4 holes.
Current my setup, Yamaha RXn-600 av receiver with 4 Bose surround double cube speaker polk rm7 center speaker and Klipsch Sw450 10 in down firing subwoofer... Current I used fiio BTA30 pro dec ..but now I need to upgrade it so plz suggestCould you please brief on your setup?
I am purely a stereo person and I do not have much idea about av receivers and their audio quality.Current my setup, Yamaha RXn-600 av receiver with 4 Bose surround double cube speaker polk rm7 center speaker and Klipsch Sw450 10 in down firing subwoofer... Current I used fiio BTA30 pro dec ..but now I need to upgrade it so plz suggest
