Suggest me a Stand for my Home Theatre
You will first need to see the 4 speakers carefully in terms of weight and hooking up options...the stands compatibility to hold that weight when speakers are not being used and its weight when speakers are being played.
Most important would be the screw gauge that fastens the speaker to the stand..check if the right size, threading is available....you can also look at Tono Systems...they make good stands backed with warranty.....I got my wall mounts from them for my Boston Speakers and it looks neat.
Hope this helps
These stands look very 'weak' but I guess good enough for satellites. While I was also looking for stands, I considered these as well as tono systems but my need was for bookshelf and not satellites. Finally I decided to get my stands from Soundfoundation. The stands looks stunning, heavy and very stable. I feel even I sit on them, they won't break. :ohyeah:
I have bought a surround stand from soundfoundation. I have placed my Sony bookshelf as surround which is heavy and the stand is perfect at a height of 35".
Where is Magma???? :D
