Suggestion needed for Grafix cards
before getting the card.. chk for the card power comsumption that you system is capable of and also the size.. if you have a compact factor or a mini size factor.. adding card will be difficult..
here is the list for prices for the cards
Capacity Model Specs XFX MSI ASUS Palit Galaxy
256MB FX5500 AGP, D - - - 1575
512MB 8400GS PCX-16X, D 1950 1800 1800 1750 -
1GB 8400GS PCX-16X, D - 2650 - - 2550
1GB 9500GT PCX-16X, D 3650 - 3400 3275 2950
1GB GT210 PCX-16X, D, DDR3 - 2900 - - -
1GB GT220 PCX-16X, D, DDR2 3600 3700 3800 4000 -
1GB GT240 PCX-16X, D, DDR3 4800 4750 4950 5200 4750
512MB GTS 250 PCX-16X, D, DDR3 - - - 6300 -
1GB GTS 250 PCX-16X, D, DDR3 7250 6550 7150 7500 -
1GB GTS450 PCX-16X,D,DDR5 - - 7000 - -
896MB GTX 260 PCX-16X, D, DDR3 11100 - - - -
1GB GTX460 PCX-16X,D,DDR5 - 13200 12800 - -
1280MB GTX 470 PCX-16X,D,DDR5 - 18925 18700 20900 -
1536MB GTX480 PCX-16X,D,DDR5 - 28600 28200 31200 -
A T I
Capacity Model Specs XFX MSI Asus Power color Zebronics
1GB 4350 ATI PCX-16X,D 2675 - - 2575 -
1GB 4650 ATI PCX-16X,D 3350 - - 3650 -
1GB 4670 ATI PCX-16X,D,DDR3 3950 4000 3900 - -
1GB 5450 ATI PCX-16X,D,DDR3 3475 - 3650 3700 -
1GB 5570 ATIPCX-16X,D,DDR3 4850 5000 5050
1GB 5670 ATI PCX-16X,D,DDR5 5950 - 5850 6200 -
1GB 5750 ATI PCX-16X,D,DDR5 7525 7175 7250 7525 -
1GB 5770 ATI PCX-16X,D,DDR5 8625 8925 8550 9200 -
1GB 5850 ATI PCX-16X,D,DDR5 16000 16100 16100 17000 -
1GB 5870 ATI PCX-16X,D,DDR5 22700 23100 21500 24300 -
2GB 5970 ATI PCX-16X,D,DDR5 39500 35000 36500 - -
my pick will be ati 4350 for 2700 rs there are 6 gpu is that series..
4350 nx ____ also have a hdmi port besides the two dvi ports.. and is 2600-2700 bucks odd
rest 3 k get a core2duo and you are good for gaming and HD movies.
A T I
Great info on the prices, Thanks! BTW, if HD audio is important then ATI 5xxx series would be able to send those thro' HDMI out...as 4xxx series have some compatibility issues with certain AVRs
Thank you for your suggestions guys.:clapping:
Actually I am getting it from a friend who is upgrading for 1k. :D
But then I have normal small ATX cabinet with normal power supply (iBall Cabinet+SMPS, that comes for 1100-1200).
I don't know if it will fit in my cabinet and if my power supply will be able to handle it or not.
Sam, I have a Sony Handycam HDR-CX150 (1920 x 1080i) and I am very happy with it.
MG.
MG.
Should do fine, a casual smps 300-350W would easily drive 8400GS based system....
BTW off topic, your handy cam HDR-CX150 ... it doesnt come with a remote to operate it, does it ..... correct me if I am wrong. (reason.... even I am on a lookout for a 1080p handycamm, and currently collating the pros and cons of all available ..)
Thanks for the info on 8400GS. So I am getting it. Let's see, 1k is not a huge amount for trials. :)
Yeah, HDR-CX150 doesn't come with a remote. I am 100% happy with my purchase.
If you want to try, come over to my place in Gurgaon. :)
MG.
There is another option "8600gt 256mb ddr3" also for 1.6k.
So this is better or "Palit 8400gs 512mb ddr2" for 1k keeping my requirement and my normal pc cabinet/smps.
Thanks. :)
better i am telling u leave this and go4 ati 4650 or 4350 more powerful than 8600 also if u want still too low then go for 8600gt.if u want 3d plus too good card go for 1gb 220 gt .
plz select 4650 and forget rest
I was looking to purchase a ATI 6850 or GTX 460 decided to go with ATI 6850 due to the better video quality for movie playback
http://forums.anandtech.com/showthread.php?p=30794868
slightly off the topic but i have 2 questions..
1) does HDMI allow passthru of bitstream of basic DD and DTS formats.. as right now i do a SPDIF passthru i wd want remove this now..
2) Some movie rips have audio tracks as AAC (Advanced Audio Coding) which until now i was encoding to AC3 (DD) on the fly from ffdshow before passthru over SPDIF, but i guess that option wont work with HDMI.. any options guys? or do i have to convert the AAC --> AC3/DTS before playing..
I know TMT3 has an option of conversion to DTS, but hasn't worked for me for SPDIF passthru.. has anybody tried the same for HDMI?
What do you all think about the nvidia graphix performance in Zotac mini pc's?
I want to move away from media player and buy this Zotac pc...
My PC is pentium 4 Daul core 3.4 Ghz , Motherboard is Asus P5LD2 . I am currently using nvidia 9300 512 Mb card but i am not satisfied with picture quality. can you guys advise any higher sound card that would make some substantial improvement in PQ,
Are you looking for HD-audio GC?
Then ATI 5770 & above will do.
But if you need only better video,then GT240(or above) which can give HW support for almost all codecs-
NVIDIA GeForce GT 240
