Hi all,
It is two months since I joined HFV. It has been a wonderful journey on my newly found love on good HiFi gadgets. Thanks to you all great FMs I have a learnt a lot, miles to go. Recently I got my first Music system with Marantz PM5005 + Wharfedale Diamond 220 speakers, which I enjoy a lot - listening more music than ever Now it is time to work on Home theater system for my Sony KD55X9000F TV in Living room.
Environment:
Size: Medium size -> 23' x 12' of height 9' = 276 sq.ft and 2500 cu.ft.
TV on wall of 12' (on 23' side) - rest of the side is wide open to kitchen entry and other room entries.
Listening distance: 10'
All glass windows/doors are dressed with curtains.
Requirement:
50% Movies + 50% Music Videos
For future expansion, prefer 7.X system than 5.X AVR (Not interested in 9.X considering rented apartment and cost)
The max budget for AVR is 40,000 to 45,000 and for 5.0 Speakers it is 1,00,000. In case of speakers I will go incremental than buying whole 5.0.
Right now, no plan to use Sub-woofer. After experiencing 5.0, if necessary will add later.
Max Volume level is moderate - Living in a rented apartment, I understood. I do close all glass windows/doors at higher volume level.
With my current basic Music system Marantz PM5005 + Wharfedale Diamond 220 in 14' X 12' room, I rarely go volume position 12
Queries:
Here are the AVR and Speakers I have shortlisted based on my requirement and budget.
1. I find Marantz NR1608 close to my budget and to be best fit for me considering 7.2/Audyssey/Network/Front-Preout. But not sure about power matching with Speakers shortlisted.
2. Please suggest Speakers from shortlisted one which can be a good match to Marantz NR1608 AVR. My confusion is Sensitivity/Impedance matching with AVR.
3. Apart from ones shortlisted here, you may please refer others too considering my requirement.
4. I am planning to go for audition in a month time. Your suggestions will help me in focusing on experience than just specification.
AV Receivers - *Amazon prices are for reference only, no plan to purchase from
Speakers
Environment:
Requirement:
Queries:
AV Receiver | Denon X1500H | Yamaha RX-685 | Marantz NR1608 |
Channels | 7.2 | 7.2 | 7.2 |
Dolby Atmos | Y | Y | Y |
DTS:X | Y | Y | Y |
DTS Virtual:X | Y | - | Y |
Sub PreOut | 2 | 2 | 2 + Front L/R |
Zone 2 | Spk/Pre | Spk/Pre | Spk/Pre |
Pass through - HDR10 | Y | Y | Y |
Pass through - HLG | Y | Y | Y |
Pass through - DolbyVision | Y | Y | Y |
HDCP 2.2 | Y | Y | Y |
HDMI IN Ports | 5+1 | 5 | 8 |
HDMI OUT Ports | 1 | 2 | 1 |
Wireless Speaker support | HEOS | MusicCast | HEOS |
IR In | 1 | 1 + Out | 1 + Out |
Bluetooth | Y | Y | Y |
Spotify Connect | Y | Y | Y |
Chromecast | - | - | - |
Google Assistant | Y | Y | Y |
Alexa | Y | Y | Y |
Amazon Music | Y | - | Y |
Siri | Y | - | - |
AirPlay | Y | Y | Y |
Ethernet | Y | Y | Y |
Wifi | Y | Y | Y |
Impedance (ohms) | 4 to 16 | 6 & 8 | 6 & 8 |
Power (W) @ 6ohms | 120 | 70 | |
Power (W) @ 8ohms | 80 | 90 | 50 |
Calibration | Audyssey | YPAO | Audyssey |
Price | |||
Hifimart | ₹57,700 | ₹43,000 | |
avstore | |||
amazon | ₹55,000 | ||
Speakers
Front Speaker Pair Price | ||||||||||
Model | HifiMart | avstore | Ooberpad | Amazon | Type | Amp Power (W) | Sensitivity (db) | Impedance (ohms) | Freq Range | 5.0 Package Price |
Pioneer SP-FS52 / SP-BS22 / SP-C22 | ₹28,000 | ₹28,000 | 3way 4 drivers- 2 Rear ported | 130 | 87 | 6 | 40-20KHz | ₹52,000 | ||
ELAC Debut 2.0 F5.2 / B5.2 / C5.2 | ₹58,000 | 3way 4 drivers- 3 Rear ported | 140 | 86 | 6 | 42-35KHz | ₹1,00,000 | |||
Q Acoustics 3050i / 3010i / 3090Ci | ₹65,300 | 2way 3 drivers- Rear ported | 25-100 | 92 | 6 | 44-22KHz | ₹1,00,000 | |||
Fyne Audio F302 / F300 / F300C | ₹40,400 | ₹50,000 | ₹50,000 | 2way 2 drivers- Rear ported | 30-120 | 90 | 8 | 36-28KHz | ₹78,000 |
