Balanced transformer should take care of differential noise
Ok I still didn’t get it. What has the ac compressor running 30 feet away got to do with music in the living room? Are u saying that the hum from the ac/ fridge compressor can be heard when I play music? Or is this noise internal in the wiring? When I put on my music setup, I don’t hear anything. No noise or hum etc. So this noise u r saying is internal?In short, you will hear the mixie motor or fridge/AC compressor run.
Which you should, otherwise how will one discern the nuances of music.
But the harmonics/noise they inject into your home grid will not show up in audio chain.
At least that's the theory.
Raghu
Internal noise. This gets injected into the home wiring and "may affect" audio performance.Ok I still didn’t get it. What has the ac compressor running 30 feet away got to do with music in the living room? Are u saying that the hum from the ac/ fridge compressor can be heard when I play music? Or is this noise internal in the wiring? When I put on my music setup, I don’t hear anything. No noise or hum etc. So this noise u r saying is internal?
Second that endorsement..... I have no association with Vertex other than being a customer but having bought a great many audio devices and experiencing dismal customer service and support, I fully endorse these guys and I feel they are doing a great service to the audiophile community .
And lastly I don't want to go OT on the OP's post, yes they make excellent step down units as well. I have a 3kva step down unit (currently in storage) which I used to run 110v equipment from ARC/Conrad Johnson/MSB/Modwright etc. without any issues whatsoever.
Sid
Congratulations. Looks a solid piece of gear. Can you also share how many equipments you are planning to connect to this stabilizer?Hi all....thanks again for all your advise and guidance. Thought I'd give a meaningful end to my post.
So I ended up buying a vertex servo stabilizer of 1 kva capacity and a vertex step down transformer of 1 kva capacity with inbuilt isolation transformer.
I got vertex hyderabad dealer contact number from a friend. Gave that gentleman Mr.Isaac a call. Since I mentioned that this was speficially for audio application where I wanted quality power. He suggested adding a servo stabilizer also in the chain, apart from step down transformer I was originally looking for.
The final bill with GST and transportation charges to my residence came to 19.8k. Expecting delivery around the month end.
I had requested for a change of those indian sockets to universal sockets. And also requested for 2 outputs instead of one. My request was accepted. Thanks for reading View attachment 39360View attachment 39361
I am planning to offload my 10 year old AVR to a friend who wants to try out with basic HTS. Mine is a US 110v model Yamaha V665/HTR-6260.I would say depending on your skill level, cost of the item/warranty etc, if you can, open the unit (demount the transformer if needed) to check numbers on it. Usually the transformers are made to cater both US and India voltages and it is just that they are hard-wired differently based on the region it was made for. If you can share the numbers on transformer with me, I can or in fact there are several techies here who can help.
Please outline the process of modding the AVR to convert it into a 220v. We are ok with the risks associated.
Maxine step down transformers are the best one. However they are much costlier as your nutribullet is 600W you may need atleast 700W stepdown transformer to convert the voltage as the nutribullet has a motor. Probably the step down transformer might be costlier than the nutribullet. Here is the link for maxine step down transformer.Hi FMs,
My query is not regarding AVR but pertaining to step down transformer being discussed in this thread.
Recently, I received a gift from US.
Its nutri bullet 600W model 110v model.
Please suggest a suitable step down transformer or any solution which other FMs might be using for this sort of appliance.
TIA
Contact Aulten @ 9811597709Hi all
Iam in need of a good quality ( mainly silent with no hum ) step down transformer for running my US voltage audio gear. I did see some Maxine step down transformers on Amazon, but not sure if they are quality enough for use in a music system. Will be grateful for any suggestions, and forum member experiences with any that they are using or have used in the past. Thanks
Contact Aulten executive @ 9811597709 on Whatsapp, discuss your requirement and they will provide a specific product matching your requirement,Hi all
Motors would be running at lower speed and lesser torque. Frequency decides the speed. It could overheat, overload and burn.Hi FMs,
TIA
