Suggestions for basic 55" led tv
Looking for basic 55" led tv for HT setup.
Room size 12 X12 feet so viewing distance approx 11 feet.
Need somthing under very tight budget of 25 to 30k max.
already have a mi box 4k so not worried about smart tv functions.
Tv will be connected to Denon 250bt.
Not sure 55" will be over or under size for room size and viewing distance.
It will be used for mostly ott and youtube videos as i do t use DTH connection.
But my biggest concern is i am not getting much 4k content online.
I have Amazon prime membership but that's not enough now i realised.
No idea from where i can get 4k stuff online.
On budget, if you want led 4k UHD , then I feel this is a good option:-
iFFALCON 139 cm (55 inches) 4K Ultra HD Smart Certified Android LED TV 55K72 (Black) https://amzn.eu/d/cPPsV0I
ALSO, if you raise your budget you can opt for qled tv :-
TCL 138.7 cm (55 inches) Remote Less Voice Control Edition 4K Ultra HD Certified Android Smart QLED TV 55C715 (Metallic Black) https://amzn.eu/d/gCeOiwm
Both are Indian products and TCL & iFFALCON both tv are serviced by TCL, In Mumbai the service is good, but it may vary in your location, so check for service first.
I hope this will help.
Finally placed order of 55u71, as per iffalcon website chat support its upgraded version of 55u61 though i am not sure.
I just hope they deliver, Lets hope for the best.
OMG its out for delivery, coming from nearby local store.
I am glad they are actually delivering i thought they will cancel my order because price was really tempting.
I got free installation too but little confused at what height i should install the tv for confertable viewing, viewing distance 11-12 feet.
Tv delivered and installed, as of now i opted for table top installation only due to some space issue and few other things.
This tv lack at some places like only 2.4ghz wifi (still play 4k videos from YouTube flawlessly), no Bluetooth and definitely picture quality not best but not worst either and i believe its delivering more then what i paid.
I have few doubts like i contacted tv with denon x250 avr via hdmi arc port, i enabled cec also but if i have to change any settings in my Avr i have to use its tiny display.
Avr menu is not showing in my tv anymore, only volume is showing.
Secondly i want to know my Avr now processing audio only or video also?? If no then how to utilise Avr's video capabilities?
Or this is the best option for avr & smart tv setup?
Btw i have mi box 4k, will it improve my system if i connect it with Avr?
