Suggestions required for budget speakers to use with Yamaha RX-V4A
OK.
I'm looking for 5.1 set in 20-30k ₹.
You can have a look at the following one - costs around the upper ceiling of your budget. The towers are capable. Although this is a 5.0 packege, you get decent low end due to the towers. You can add a sub later.
I am building a living room setup from scratch and can stretch upto 50-60k for a 5.1 or 3.1 setup if possible. Will be getting a 1500 or 1600h (denon), but have separate budget for that.
Here are some pre owned options, audition, read reviews and then make a decision....bargain as much as you can...Delhi based sellers.
This is a good system, audition and bargain included with AVR
Entry level system
