Firstly welcome to HFV.
Based on the specs you have shared, any good Stereo Integrated amplifier will do. It depends on how big is the listening area you have. 120 watts would be the peak. You can pair amps from 25-30 watts per channel as the speakers have high sensitivity which means less power can be used to drive them!
If it is within 150 to 200 sq feet, a decent 40+40 watts of Marantz should suffice. If you are used to hearing music continuous at loud volumes, then look at 75+75 Watts RMS as minimum.
Based on your budget, see for such amps, share a list with us and we can then help to shortlist the best for you. Audition where possible. There are dealers who even offer a home demo, check this and if possible would be great to have a home audition which is better as then you will really know how it sounds and what will be the right one as per your home placement and environment.
