Surround speakers recommendation
Hyderabad
Hello All,
This is my current setup.
AVR : Denon X1700h
LCR: Q Acoustics concept 40 and concept centre
Sub : SVS SB 1000 pro
Now planning to add surrounds. Concept 20 seems good match as surrounds but looks like they are EOL.
Please suggest any alternatives, Does Q 3020i works ? Thanks
Brand matching is not necessary for surrounds. The 3020i make for great surrounds , i used concept 20 fronts,3090 center & 3020i surrounds in my prev HT setup and did not find any tonal mismatch. The concept is even a better center
Hello All,
AVR : Denon X1700h
Yes ,it will perfect suit for surround
Hello All,
AVR : Denon X1700h
I am using Q Acoustics 3010i's as side surrounds with the Q Acoustics Concept 40 and Centre as LCR. The combination works just fine. I was using JBL Control One's as side surrounds earlier and those sounded a good match too with the rest of the setup.
