Technics RS-M22 has no volume control
zulutribe
Singapore
Hi all
I have recently bought a Technics RS-M22 cassette deck and I hooked it up to my M-Audio Firewire Solo via line outs to digitize my cassette collection.
I'm running into a problem though. The M22 does not have output volume control knobs (line out/headphone), the signal coming into the Solo is a little low and the Solo does not have input gain for rca input.
I could increase the volume via recording software but I'd rather increase the signal before it enters the Solo.
Any advice?
ideally you can build a op amp based preamp to increase the gain. You're looking at <100 rupees worth of parts and some soldering, maybe more if you want audiophile grade components.
Else a headphone amp should do.
Thanks for the reply.
Can you explain what is an op amp and where can I find instructions to build one? I'm no engineer but I can give it a shot if it's not too difficult finding the components needed.
The Firewire Solo can work standalone without tethering to a computer so that sort of works as a headphone preamp. But again, even after maximum on the headphone knob, the signals way too low.
Otherwise, which headphone preamp would you recommend?
I have Audio Technica ATH-M40fs headphones and ATH-IM50 in-ears.
I once encountered a challenge when we had to connect a cd player to an old amplifier and the cd player was overloading the amp's input. I used this simple shunt technique which I had earlier used during our kiddy days to make line recordings using a small tape recorder which only had a mic input.
Here is the philosophy:
Increase the value of R1 to drop the gain further.
yes, that should work fine. a bit expensive, but will work
EDIT: dumb question - are your windows mixer levels all maxed out? including the recording level sliders?
Yea, that will work if I'm going into the Solo mic input. However, there's only 1 mic input. :(
Yup, the sliders in the software are all the way up. Technically, I could increase the input signal by sending it to another virtual channel and add a gain plug-in in between. But that's all in the software which I want to avoid.
