keith_correa
What are you talking about? Whom to contact for what? Am "silent" because I try not to post frivolously.You know whom to contact, dunno why you are so 'Silent' now![]()
I can hear the sound of silence![]()
No need to be sorry! Was just wondering what you meant when you said I know whom to contact. Am still wonderingReferring to your post above, if misunderstood then am sorry.
No need to be sorry! Was just wondering what you meant when you said I know whom to contact. Am still wondering![]()
1. Badly wound transformer having huge primary to secondary leakage capacitance, so that it can pass RFI in free-flow. Lack of Faraday Shielding.
I will come to smps part in next posts.
Is there an easy way to measure this? whats would be the ball park limit beyond which the capacitance is too much. How do I check for faraday shielding, without opening the transformer. Are these things applicable to all kinds of transformers, ei, torroidal, r-core etc.
2.5 sq.mm is 14AWG which in all likelihood is more than sufficient for your needs.Not sure if i am posting this doubt in the correct thread, but looking at the thread name i thought to post it here.
I am using Bandridge Superflex LC1259 speaker cables for my music setup. Following is the product link:
Bandridge - General
I need your help in understanding the following:
1) what is the guage of this cable. I tried to search through google but i got different results. i.e. almost all the numbers from 12 guage to 20 guage for the same cable.
2) I need some feedback on these cables, if anybody has used them in past. I basically need to decide whether to continue using the same or to buy new ones under 400 to 500 rupees per metre.
Regards, Amit
its a 20 AWG... model LC 1259 introduced in 2004.
for the tannoy's and marantz which is pretty decent go for minimum 16 AWG oxygen free copper..
dac 16 awg/ chord carvinal should be good start.. dont over spend but get decent ones..
MX cables are good as well..
If you want to upgrade (debatable) consider the Chord Leyline. Inexpensive.
