M
I dont know which material to use to replace the thrust pad - should i need to.
Open and inspect the thrust pad. If the dimple is deep, use the reverse face. Else buy a Fender guitar pick of similar thickness as the pad. It's made of delrin and perfect for the job. Cut it to the same size as the thrust pad and you're done.
JlsOpen and inspect the thrust pad. If the dimple is deep, use the reverse face. Else buy a Fender guitar pick of similar thickness as the pad. It's made of delrin and perfect for the job. Cut it to the same size as the thrust pad and you're done.
Jls
On the reverse side.. Should I make a small dimple and rest the bearing in it ?
Or simply use the reverse face as it is..
Looks very nice
Edit: It looks from the pics that motor transit screw are fully screwed in. The two red screws should be loose. You can even completely remove them.
Sachin
If you're that afraid, get an Mp100/110 stylus for daily driving - they are interchangeable and a lot more affordablethats the part i am most scared about... i mean i am afraid of hurting the cartridge..
