For better result use HEOS App.While streaming through my Marantz NR1509 through Bluetooth I noticed most of the MQA songs are quieter than HiFi ones. My phone uses AAC Bluetooth codec. Has anyone noticed this issue?
Thanks Mani...tried with Heos and it works. Only constraint is that Heos doesn't have a clear layout like Tidal instead it's extremely basic. Guess will have to get a long list of playlists made.For better result use HEOS App.
Who all are interested in Tidal Turkey Family plan, can contact me via PM. Then we can discuss about how to proceed with this
Hi @SachinChavan
Now I have something more to say about Qobuz sound quality. My free trial with Qobuz is over and I am back to Tidal again after being with Qobuz for a month. I have started to feel the difference now between Hi Res music on Qobuz (24 bit- 192Khz) and 16bit-44.1 Khz on Tidal. Not that everything on Qobuz is of that quality but whatever is, you really enjoy the dynamics, clarity etc etc. I am bit short of words here. In short difference is audible.
But overall the app eperience was not good, as I mentioned earlier as well, many a times playback stops randomly. One thing that was very anoying for me was, if I abruptly switch to another artist/album, the output to dac stops. I had to re route the audio from app to connected DAC it somehow forgets where to feed the audio.
It didn't happen if I skip the tracks with in the current album/playlist. Not sure if some one else has experienced this too.
At last Qobuz is not cheap as compared to Tidal Turkey. I would stick to Tidal for now.
Vivek
Any body experienceing this type problem while playing Tidal.
Frequently songs being played are stopped after 2 or 3 mins of play. Then reconnecting after few moments and starts playing from begining.
Sometimes showing communication lost.
Felt the same after listening to Qobuz for a month.Is it me only or others also find tidal lossless not upto real lossless wav files in terms of audio quality. They seem low on resolution and dynamics.
Yes same thing happens to me randomly, sometimes more often, dunno what is the reason but for sure is frustrating as Spotify works good & smooth off course with inferior qualityAny body experienceing this type problem while playing Tidal.
I am on Turkey Account.Yes same thing happens to me randomly, sometimes more often, dunno what is the reason but for sure is frustrating as Spotify works good & smooth off course with inferior qualityI m connected to Tidal US if that helps are you on US account too?
Hmmm, could be the BluOS app being the issue for me too then. I noticed only few tracks skips or pauses while the rest play fine.I am on Turkey Account.
Problem is through Play-fi app only.
When playing through Bluetooth or playing through my sony x9000f tv there is absolutely no issue at all.
Even playing Dolby Atmos music through tv, no problem at all.
I also would like to know the ideal setup to enjoy Tidal.Hi, new member here.
Which earphone/headphone do you use with Tidal? Does true wireless earphones like Airpods/Sony support HighRes audio?
i mean FLAC or ALAC
I have a budget phone Xiomi Mi A1 and just started out using Tidal and the HiFi music experience. I am currently using basic earphones(Blaupunkt EM10 Wired earphone). What would you recommend for a budget of INR 7K to 10k (converted to about $96 to $136 USD).?
I am open to both IEM as well as Headphone.
Do i need to buy a USB DAC?
