TIme to upgrade my aging Anthem AVM20 - HELP
Sqzdachrmn
Overland Park, KS
So much has changed since I last upgraded my home theater. I am thoroughly confused. I use to be firmly in the separates camp, but I am warming to AVRs and have a nice performing Pioneer Elite in my living room. I also have an ATI 1505 that will still be power for this system.
So here is why I am upgrading. My Arcam has zero HDMI ins or outs. So I have been running directv directly to my Runco projector. We have added an Xbox one and the out of the Xbox One is problematic and I am forced to run directv through the XboxOne. Its time to add a blueray player to my Home Theater setup, I have blue ray through out the rest of the house. Yes I am late to the game for my HT room, but my Arcam DV88 is such a sweet player and life and kids happened.
So my dilemma. Do I just add an Oppo BDP 103 and have it switch the Xbox and Directv? The anthem sounds great, it has optical in. So I could add a BDP and just video switch. Or should I serious consider one of the following: Emotiva UMC-200, Outlaw 975, Marantz AV7701, 7005 or a Marantz SR7005. Im really open here on brands. I really want to stay away from 1500 plus pre/pro at this time.
Side note. I will be upgrading my projector most likely to an Epson 5030 or equivalent in the next month or so.
Current System: Anthem AVM20, Arcam DV88, ATI AT1505, Meadow Lark Audio fronts, Paradigm Reference CC, Paradigm Servo 15 sub, Def Tech Bipolar rears.
Your input and thoughts are much appreciated.
Hi sir,
I see you are using a Runco projector, so I assume that you are well aware of the picture and build quality of these projectors.
I have a 3chip dlp runco for sale(model: Ls-10i). I am offering it as its an overkill for my room size. But I suppose you can benefit from this deal. Let me know if you are interested. thanks
nqpSam
Hi, Having used Anthem and known that it sounds great I am surprised that it is not there in your list. Just don't go away from Anthem, seriously consider MRX 510 and need be you can add your ATI 1505, I am sure this will give you a great setup. As far as the Blue Ray player, you can you can consider Panasonic BDT500 which is available only in US and Europe and I am sure you will never regret. I think both put together you can bring it in your budget.
I am suggesting Anthem after a long journey which you can know from the following threads.
http://www.hifivision.com/my-audio-video-setup/47854-my-home-theater-journey.html
http://www.hifivision.com/surround-amplifiers-receivers/47864-anthem-room-correction-av-setup.html
My two cents.
R. Balagopalan
