RajithKumar
Nice ,how did u manage to hang tsx110 on ceiling..specify the brackets ,so that it will be helpful for FM.Polkaudio TSX 110B
TML and TMR
[emoji41]
Sent from my ONEPLUS A3003 using Tapatalk
TML and TMR
[emoji41]
i am also in same process. can you please elaborate how to fix these to ceiling and speakers. where we can buy ?2 numbers each does the job for 2 speakers
Practically Yes if your pipeline accommodate it.Can we put speaker wires and electric wires in same pipeline ?
This is not Dumb Questionbecause sound waves are Electromagnetic waves. will it cause any disturbance while using speakers.
I read somewhere should not put both wires together. Conductor is right term ? I m not sure.Practically Yes if your pipeline accommodate it.
If i answer this there will be big discussion follows for sure.
Moreover here IMO you are suppose to mention as conductor and electrical charge - Pure physics
@elangoas i have seen this at MX outlet.You can also consider some brackets if you have thread mount on the speaker.. MX Speaker bracket - https://www.ebay.in/itm/MX-2pc-Spea...136671?hash=item3f8fe5b91f:g:~JEAAOSw-itXwuVP
Since you are from Chennai, check the MX store (Vinsun Agencies) in ritchie street.. Should be easier to tilt & turn the speaker to the listening position..
@pvel07Speaker stand you can purchase from MX outlet it cost somewhere around 600- 700rs i remember .Ebay link for MX speaker stand
But i feel it is not good enough to handle speaker weigh more than 2 - 3kg ( They claim 10+ kg)
Eye bolts can be purchased from local hardware shops.
