Tone Arm Wire
vmscbe1974
coimbatore
Friends can we get TOne Arm wire online in india? Is it with aluminium or Copper wires which is best or a simple single core wire sufficient to take the signal.............
Srinivasan
What are the connectors to be used here for connecting the wire from tonearm to cartridge?
Open up the female serial port socket of old dial-up modems and use the connector barrels inside the socket. Let me see if I can post a pic. the same is also found in old serial mouse..
I have used both headphone wire and mouse internal wires as per suggestion from Lifewater.
They work superb!
Using headphone wire is the easiest DIY out of the two, you do not even have to strip it, it is ready for use.
