topping tp20 and speakers or powered speakers ?
subabu2002
ERODE , tamil nadu
hi all,
i just knew that topping tp20 through hifi vision forum...
how good they are? i owned some powered speakers for PC and sounds good..
i have some old 4 inch modaurnt short small speakers that sleeping in bag for years.. i would like to use that speakers via topping tp20..
if i use topping tp20 and MS speakers, does it sound good like powered speakers (audio engine a2)?
any ideas?
-suresh babu
You need high SPL speakers for such low power amplifier.
I heard TP20 with my Cabasse Joursey for a very short time. They sounded clean, fresh, pleasing for mids and highs. Bass to me (with open baffle experienced ears) was apt.
thankyou.. i would like to use only for PC purpose with close listening..
Hi topping will be a very good choice for near field listening. Any speaker having more than 86-87 db sensitivty will do well in such scenario. I am a huge topping fan so pl consider experts views also. A2s are also very good spkrs so not sure if this combo is an upgrade but if u got decent spkrs than you cannot go wrong with t amps. Good luck
thank you prosenjit..
my speakers are mordaunt short..20-80 watts @ 8 ohms.. 3 inch speakers
-suresh babu
Yes! people used that amp for PC speaker purpose. Install the amp in one box - provided socket for DC 12V input and audio input wires with 3.5mm pin. One channel output used within the box and extend output of another channel to another box using 1-2meter wire. That's all!
If you have tweeters in same box then just connect it parallel to speakers through 4.7F non polar caps.
