Eh? Isn't Dell Ultrasharp 23" a monitor?? Dell makes quality products so even for ~16k, I'd still say it's good.
1) As with all LCD displays heat is not a problem at all.
2) It is not HD ready. In all probability it will be 1920x1080 (if not 1680x1050). Again I think you have mistaken a computer monitor for a TV. Please correct me if I am wrong. Text will be very sharp as on any other monitor.
3) It should be just about perfect for gaming.
I would recommend this display as a good computer monitor and not as a TV. For browsing, programming, and document perusal you'll be hard pressed to find a better display.
I think my query was not clear.
I am planning to buy a dell ultrasharp 23" at 16k and was asking how this toshiba TV 32AV700 fares against it as a monitor only (not for TV viewing) in the parameters mentioned in my earlier post.
In short, If my requirement is only computer monitor, does it makes sense to buy toshiba 32AV700 against the likes of the ultrasharps as it provides me with more real-estate and is a TV grade panel. (Heard that non-IPS monitor panels are made of inferior TN panels while none of the 32"+ TVs use these.
