Yelamanchili manohar
I would fully agree with the above suggestion to keep the preamp separate if space is not an issue. Every preamp adds its own subtlety to the mix. And once one finds that preamp, it is a keeper for life. We can change power amps, dacs and speakers, but once we are fully aware of the sonic signature of the preamp, it is easier to decide on the other bits. Almost all the dacs I've had, came with some kind of volume control, and a few with a fully analogue preamp section. But none of them match the sonics of a dedicated well implemented preamp in my experience.Barring a highend Lampizator Atlantic or something, most tube DACs(AMR 777, Mhdt hawana, Thyaga V2, AudioNote 1.1x), I felt are a trade off. The tradeoff of The HF rounding, Contracted Soundstage and slightly increased noise floor would always put me off from buying one. But the DENSITY of the sound (or analogish feel) of Good Tube DACs (Lampizator or AMR) would make analog setups costing more than Rs 10L run for their money. If that's what you are looking for, then you wouldn't disappointed, but I doubt any tube dac under 2L will be able to achieve that level of performance.
But there are many small time boutique tube DACs Manfactures in Europe and USA which are relatively cheap (Under 2k USD) and could be good enough. You should be searching for them. Anyways combining a DAC and preamp in a same chassis hasn't worked for me ever ( Other than AMR DP 777), so I'd advice to go for 2 box solution, if you could share rest of your chain it'll be easier to suggest something else altogether.
