GM Mahi,
My valves looks like original Bel (India). I have not tested it though as My Radio on/off control has turned intermittent. Also My EM84 socket needs to be replaced pobably along with some capacitors. I am also planning to make on/off switch for this signal indicator valve. As these valves (fluorescent) easily go out of service with constant use. So will take time to test. I have tried to capture lable marks of the valve. from that point of view they look original. The Boxes are new and someone must have imported boxes which are easily available in 'foreign' markets.
If you are worried about Cleartop which in some valve indicates the valve has lost its vacuum it is Not so. Some cheap unimportant valves had no 'Getter' process. which marks the valve black on top.
However I will update once I fit the valve in my radio.
