Turntable mat
Good idea!
BTW, I'm playing the new mat. Sounding good [emoji106]
And the colour nearly matches the colour of my speakers:)
Since it's brand new, it's not totally flat. Tonight I'll place it below the TT's heavy platter to flatten it.
PS: after four tracks, cleaner highs and much better separation is apparent.
Great to hear that.
Sachu also mentioned about better soundstage.
Sent from my MotoG3-TE using Tapatalk
Just an idea, can we use old LD discs instead of acrylic? I have some.
Regards.
Good idea, i have few old records . Will give it a shot.
Once ready i will update you all. If anyone wants to test i can ship it.
A little roughening of surface of acrylic mat can help by friction so as vinyl doesnot slip. The center weight can be reduced.
The Vinyl as mat is very good idea.:thumbsup: Exactly same material the vibrations will pass through easily and will have friction.
Regards.
I have few old records . Will give it a shot.
Good idea:clapping: I also thought but lps tend to wrap little bit. But the LDs are very strong like CDs but thicker. Sure, you must have seen LDs previously.
Regards.
In fact I believe the mat EMT uses is same material as vinyl. That's what I read somewhere.
Hello all,
I have received request for couple of mats. Let me know if anyone is interested.
Nishant
Hello all,
Please add required diameter and thickness of mat.
3mm is easily available. Above 3 need to confirm.
If you have a 78 rpm shellac or 10" vinyl EP please try them as mat. I'm currently trying out a 78.
